https://www.dackonline.se/cgi-bin/rshop ... p=R-260359
finns det nå dugliga däck till bra pris någonstans ? exemplet ovan var inte dugligt, och därmed är priset odugligt också
bert skrev:Hmm var det inte Michelin som hade nån app med lufttryckstabeller? Ja det kanske fler märken har
Two-number Tire Sizing
Lawn tractor tires using the two-number system display numbers as 4.80-8, for example. This means the tire’s width is approximately 4.8 inches and the rim is 8 inches in diameter. Those are the only two numbers you need to find the right size replacement tire.
Three-number Tire Sizing
The three-number lawn tractor tires numbering system works a bit differently. 15×6.00-6 is a common size. The first number before the “x” indicates the tire’s diameter when inflated and not under load. The middle number between the “x” and the “-,” indicates the tire’s width. The final number indicates the width of the rim. Note that the last number is width, not diameter of the rim. This is always the case with three-number sizing for lawn tractor tires and other garden equipment tires.
Återgå till [Allmänt] Däck/fälgar/hjul
