Restoring an old Högbo lathe (svarv)
13 inlägg • Sida 1 av 1
klaas0639 (trådstartaren)
#1 » 19:57:59, 05-05-2013
I am Dutch (nothern part of the Netherlands). I have a few questions, probably can be answered by this swedish forum.
Recently I bought an old maltreated but beautifully designed small lathe. The trademark as was indicated on the lathe is"" Triton Junior"". But I could not trace any lathe manufacturer called Triton. Via help of a dutch forum I found out that it is a swedish Högbo lathe.
Below a few pictures of the lathe. As you can see it is dirty and locally rusty. None of the bearings rotate well but as far as I can see there is no fatal damage nor play in the bearings of the main axis.
My plan is to restore this nice machine or at least to bring it back into a status that it can be used again for basic lathing functions.
But, I do not have any data of Högbo.
Could somebody of this forum give me any help in tracing the particular type of this lathe and any documentation like partslist, exploded view or manual? Probably somebody of you owns such a lathe and can advise me about restoration.
The images below speak for their own. In particular from the last three images show details which made me conclude it is a Högbo lathe.
kind regards
klaas0639
ps: you may answer in Swedish. It easily can be translated by Google.
klaas0639
International
Maskin: Högbo 75; kleine draaibank ongeveer 80 jaar oud en van Zweeds fabrikaat
bangt
#2 » 20:09:07, 05-05-2013
bangt
#3 » 20:25:45, 05-05-2013
Bangt, thanks. I am aware of that beautiful site ; it helped me to find out it is a Hogbo.
Do you have any experience with these Hogbo machines?
Is there any change spare parts can be traced on swedish second hand market?
Kind regards
klaas0639
klaas0639
International
oler
#4 » 18:14:50, 08-05-2013
http://ironbill.se/pages.php/page/nyheter
"080405 Ironbill AB har köpt rättigheter, gjutmodeller, ritningar och reservdelar till svarven Högbo 75 som tillverkades av Högboholms Mekaniska Verkstad. Vi kommer att ta upp reservdelar i sortimentet succesivt under 2008. Delar som är gjorda efter orginalgjutningar."
Dom kanske kan hjälpa dig om det är något speciellt du behöver.
//Olof
oler
Maskin: Yanmar sv100
Ljungby 1016
Valtra 8950Ht, M130
Div. Verktygsmaskiner
#5 » 20:24:39, 21-12-2018
Well it is a long time since my last input. There were several reasons why I had to postpone the restoration of my Högbo 75. Anyhow, recently I could continue this project. I succeeded in buying a second Högbo 75 of which the housing of one of the headstock bearings was cracked (ZAMAK). This lathe I will use as a donor of spare parts. Both lathes are disassembled now. Several parts turned out to be in bad shape, maltreated or missing but I think I can build one complete lathe out of these two.
The donor lathe (before disassembly) with a set of gears for threading and nice other accesories.
As a result of this restoration project I got strongly interested in the history of these Högbo lathes and in the Dutch company “”Fred Ouwerling and Co ” who imported it from Sweden to the Netherlands.
(in an earlier contribution I added a picture of the trademark emblem ”Triton junior” It was on both my lathes. Was this emblem on the ”Dutch” Högbo 75 only or is it an emblem Högbo used? I noticed that this emblem is on the Högbo 75 on http://www.lathes.co.uk/ too.
The Dutch company who imported the lathes does not excist anymore (terminated since mid sixtees) In (Dutch) archives I found some interesting historical data but in fact no answer on the most important questions, like: How was it possible to import these lathes during the war. Was there a direct relation between this Dutch import company of Fred Ouwerling and the Swedish manufacturer or was the import part of a bigger ”deal” ( forced by the Germans) of import of Swedish machinery?
On top of that I am searching for the history of the Swedish manufacturer Högboholms Mek. Verkstad 340 37 Torpsbruk, Complication is that also this company does not excist anymore and the company who took over, http://www.ironbill.se , does not react on my questions so far.
Are there any members on this forum having information on the former Högbo company or any hint how to get introduced to ironbill. It might be of great help if I had a name of a relevant employe at ironbill.
kind regards
Klaas
klaas0639
International
#6 » 20:56:16, 13-02-2019
Min sökning på svarv Högbo 75s historia, den svenska tillverkaren och den nederländska importören Ouwerling, gör framsteg. Det verkar som att det tidigare företaget Högboholms Mekanista Verkstad fortfarande finns, men nu som ett mycket litet företag. Adress: Rönningerryd 5; 342 95 Alvesta; Sverige. Förhoppningsvis finns det information där. Jag hittade inte en e-postadress och skrev därför ett brev. Jag kunde också ta kontakt med Ironbill (det företag som tog över Högboholms Mekanista Verkstads rättigheter) genom ett svenskt förhållande.
Från en annons i en holländsk / tysk tidning i juli 1942 att bolaget Ouwerling utom Högbo 75 (under namnet "Triton Junior") är också en större svarv, den "Triton Senior" i Nederländerna kommersiellt utsläppt. Båda namnen är tänkt av Ouwerling och har inget förhållande till tillverkaren.
Jag lägger annonsen nedan. Tyvärr är kvaliteten på bilden dålig, men för närvarande har jag inte en bättre bild. Mest uppenbart är att båda "" Tritons "är från Högbo Mekanista Verkstad. Vare sig från de baltiska staterna eller Ukraina. Det nederländska företaget Ouwerling hade kontakter med branschen under kriget. Jag sökte på http://www.lathes.co.uk/ men hittade inte den här banken ännu.
Har någon ett förslag på vilken bank detta kan vara?
bild link fungerar inte
Klaas
klaas0639
International
#7 » 23:03:05, 13-02-2019
Oj, det är något fel på bilden. Jag ska försöka fixa det.
hälsning
Klaas
klaas0639
International
#8 » 23:03:05, 13-02-2019
Jag har tagit bort bildlänken förrän jag löste problemet.Sorry
hälsning
Klaas
klaas0639
International
Fragels
#9 » 13:38:36, 14-02-2019
Thanks for sharing.
I guess the lathes sold in 1942 would have been stock brought to the Neatherlands befor the war.
Triton Junior does not sound typicaly Swedish. Might be a Product name added by retailers.
There where numerous lathes of this size from a number of manufacturers around the World.
If you are lucky parts from these might be a direct fit.
Fragels
#10 » 20:19:58, 14-02-2019
@Beerbringer:
Det finns indikationer på att svarvarna infördes under örat. Det gör allt så intressant.
Med vänliga hälsningar,
Klaas
klaas0639
International
#11 » 23:14:25, 15-02-2019
Från en annons i en holländsk/tysk tidning av juli 1942 verkar det som det nederländska företaget Ouwerling och Co, förutom Högbo 75, också lanserade en stor svarv, "Triton Senior" i Nederländerna. Namnet "Triton Senior" skapades av Ouwerling och har inget samband med tillverkaren av svarvningen.
Jag lägger annonsen med bilden nedan.
Det mest uppenbara är att denna stora svarv också är från Högbo Mekanista Verkstad. Men Ouwerling hade också kontakter med industrin i Baltikum och Ukraina under kriget.
Har någon ett förslag som banken kan vara?
Klaas
klaas0639
International
aloalo
#12 » 16:48:01, 08-12-2020
Hi Klaas,
I have inherited an old Högsbo 75 that I intend to restore. There are not much info on the net but I found your tread. The vee pulley discs need to be replaced, have you any information where to find discs that can be used? There is no Triton junior stamp on my lathe, it is bought in Sweden.
aloalo
1 inlägg
magnusk750
#13 » 19:17:38, 08-12-2020
Klaas, I think you should try to call Ironbill by phone. Perhaps before "I will call you from this number... at x o'clock". Swede's often don't answer to foreign unknown numbers, for good reasons, lot's of frauds.
magnusk750
