Dear experts,
Now spring has come and we started to overhaul our favorite Akerman.
Please tell how to knock the old spherical bearings ears? First warm? Or you can cut it?
Kära Expert,
Nu har våren kommit och vi reparerar vår älskade nachalikapitalny Ackerman.
Berätta hur att slå de gamla sfäriska lager öron? Värme? Eller skär?
Well,,, either you can use heat and a pullers or simply grind a slot in an angle across the bushing using a pneumatic straight grinder and then hammer it out when tension has released.
krokodilen skrev:Well,,, either you can use heat and a pullers or simply grind a slot in an angle across the bushing using a pneumatic straight grinder and then hammer it out when tension has released.
Better ideas anyone?
/Christer
no Im agree. thats a way to do it.
I hope you have taken out the pressure locking springs? The bearing shoudnt be so hard to knock out.....
Er det ikke at vanlig lenklager dette da???
Ingenting er umulig,det tar bare litt lengre tid....
