580C Mangled Track Gearbox
71 inlägg • Sida 5 av 5
Andy80
#61 » 14:55:44, 16-01-2019
It is not so very big job, can be a little tricky due to the limited working space, but it will definitely be worth it when your done and have an almost modern machine when it comes to operating. You will have to replace the springs in the valve blocks to lighter ones. Here is a picture of mine when done.
Andy80
Maskin: Hymac 580B
dolmenman (trådstartaren)
#62 » 15:01:01, 16-01-2019
Looks excellent...The linkages in my machines levers are very worn so it would be an idea to do this instead...I will probably have the seals to put in the rotary distributor first as it is beginning to weep a little oil...
I would never be finished if I did everything that needs to be done on this old machine.. :aaargh:
dolmenman
International
Maskin: Hymac 580 C
PeterR
#63 » 22:16:16, 16-01-2019
Question from a amateur:
Is it normal to have the bucket at left handle? Or is that just “Hymac standard”?
I thought that normal is: left/right and slew are operated with left handle, and boom and bucket are operated with right handle?
PeterR
#64 » 22:37:17, 16-01-2019
As far as I know, it's just Hymac although old JCB's, Priestman and other English makes could be the same...Someone here will know for sure...
dolmenman
International
Maskin: Hymac 580 C
texas5020
#65 » 10:23:18, 17-01-2019
I can see the key to success beside the pipe ! :thumme:
texas5020
Hanomag B8 B lastmaskin
Harley Davidson Road King -05
Lambretta LI 150 -60
Husqvarna Rider
m.m...
#66 » 10:53:05, 17-01-2019
A big nut needs a big key!!! :hurra:
It was for knocking the bearings in...
dolmenman
International
Maskin: Hymac 580 C
#67 » 11:51:48, 17-01-2019
Decided to look in the other gearbox to see the state of the oil....looks like I was right to do so judging by this sludge..
dolmenman
International
Maskin: Hymac 580 C
Andy80
#68 » 15:10:11, 18-01-2019
Andy80
Maskin: Hymac 580B
#69 » 16:57:29, 18-01-2019
Yes...that is just after I got her in late 2016...A guy filmed me for his "Awesome Earthmovers" YouTube Channel...I was a bit of a novice then...
Here is some more I filmed myself... https://www.youtube.com/watch?v=CYy_wcg6Jac&t=50s
She is loose with the slew and I am looking advice on adjusting the cross line relief valve to see if that helps...Maybe I should start a new thread...
dolmenman
International
Maskin: Hymac 580 C
Andy80
#70 » 17:04:48, 18-01-2019
Nice video :grin: Only i can detect just a slightest bit of clearance in the bucket linkage :vissla:
But after all its an old machine, you seem to have a nice long dipper arm by the way :thumme:
Andy80
Maskin: Hymac 580B
#71 » 19:49:34, 18-01-2019
Thanks....Since then I have welded several lines of weld on the pins and grinded them down as it was the pins worn, as well as replacing seals and eyes in the bucket ram and fitted new(er) bushes that I got from our local breaker...It has tightened it up but would need to replace the bushes and pin for the pivot between the dipper and boom...
The guy that shot the video makes other videos and here is one filmed at our local breakers yard of a Hymac 580D https://www.youtube.com/watch?v=ys9bYPHsfq4
dolmenman
International
Maskin: Hymac 580 C
Återgå till Hymac Technology
