Various restorations/projects from Bosnia
698 inlägg • Sida 46 av 47
selmir_Bosnia (trådstartaren)
#676 » 12:47:21, 14-09-2020
Hahaha, good point! I would tie them down somehow to the forklift :)
selmir_Bosnia
Ort: Bosnia and Hercegovina, Ugljevik 76330 Janjari bb
Maskin: IMT 539
Zetor 7045
Hako Hakorette+ACME 8HP engine
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
PeterR
#677 » 15:52:08, 14-09-2020
selmir_Bosnia skrev:About the loader you mention, what do you think about this soulution?
https://www.olx.ba/artikal/39718452/uto ... a-grajfer/
I coud make something linke this for my small tractor, it is more agile so I could maybe use to to load manure and not do it by hand anymore.
When I was young, we had a similar loader. Useful and better than nothing. There is a manufacturer who offers a loader with sort of the same concept, but much more sturdy. Google “Sweloader”. You might be able to copy that? (Be aware! Patents might be protecting it, and I personally know the owner of the company :laes_detta: )
https://swedeloader.com/
PeterR
Bengt Erik Eriksson
#678 » 21:53:05, 14-09-2020
Patents is to protect against copying for marketing. If you do a copy for your own fun and use it is okay. But you should tear it apart instead of selling it when ready with it.
Bengt Erik Eriksson
Maskin: AVANT 218 -11
MF 575-77
Zetor 3011 -63
Zetor 5511-71
Famall EMD50-54
Bm Volvo LM 640-69
#679 » 21:57:12, 14-09-2020
It is very interesting solution. I am a bit confused with those backplates down there, i do not get what are they for or what to do with them.
Sent from my M2006C3LG using Tapatalk
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
PeterR
#680 » 22:34:31, 14-09-2020
I believe the loader frame is resting at lower edge of hitch arms, perhaps bolted? Have you visited the website? A lot of interesting information and informative illustrations.
PeterR
#681 » 10:36:35, 15-09-2020
Yes, meanwhile I saw lot of images and got it. Backplates indeed rest on hitch arms.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#682 » 06:38:48, 23-09-2020
We are finishing our annual overhaul so everything is going back to its place.
IMT577 (70HP made in Yugoslavia/Serbia) pulls 17 tons 1MW 6kV engine for coal crusher.
https://www.youtube.com/watch?v=a6PDi_u41QA
Locatelli mobile crane leaving the compoung after loading the engines.
https://www.youtube.com/watch?v=cJOtIjE4h_k
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#683 » 06:35:12, 20-10-2020
Hi guys!
As usual, I am extremely bussy, lot of work on my job and even more at home. We managed to harvest our corn, yield was very good. After the harvest I mulched the fields and now I am ploughing, as soon as I get home from work i jump into tractor and work until the dark, I do not dare to work during night, there are too many migrants from middle east hiding in the fields so It is not safe to be there after dark.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#684 » 06:39:06, 18-04-2021
Hi my friends!
Originalets URL: https://uploads.tapatalk-cdn.com/20210417/7e68f74d00be024e90464ca18da264d1.jpg
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
Sparrow
#685 » 07:54:35, 18-04-2021
Hi selmir :wave:
Sparrow
#686 » 07:59:36, 18-04-2021
:wave:
#687 » 21:12:41, 18-04-2021
I am so bussy I simply have not a single hour of spare time for months. Not a single free day for 2 weeks, worked yesteray and today for 16 hours straight. Yesterday we were finding and designing the route for new turbine oil coolers piping trough the existing pipeline maze. Today we fought with turbine shaft couplings, there is a minor "twist" between high pressure stage, medium pressure stage, low pressure stage and generator shafts (turbine is made out of 3 stages that are connected by rigid couplings. New bolts had to be made so every single hole had to be measured with micrometer and angles checked.
Originalets URL: https://uploads.tapatalk-cdn.com/20210418/e8a5603c2d47675d833e1555ae560778.jpg
Large gear behind me is used to slowly rotate the turbine and generator after the shutdown until they are cold enough via external 32kW engine with gearbox.
Originalets URL: https://uploads.tapatalk-cdn.com/20210418/04a52fb520c1b71a0d380527a28d0873.jpg
Originalets URL: https://uploads.tapatalk-cdn.com/20210418/18c2b100cc320ab824576bdef78fa02e.jpg
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
#688 » 21:18:16, 18-04-2021
Cleen and sober workarea :thummar:
#689 » 16:28:47, 10-07-2021
https://www.olx.ba/artikal/42674399/valmet-massey-ford/
Hi guys! What do you think about this tractor, is it good? Price is 9000 eur.
selmir_Bosnia
Maskin: IMT 539
Zetor 7045
Stihl FS20
Stihl 056AV Super
AL-KO 4535 II
Husqvarna 240R
Stihl FS20
Stihl 050AV
Jonsered 2050
Sparrow
#690 » 17:06:23, 10-07-2021
Valmet is a good tractor, however it always depends on how earlier owner have take care.Check everything in the 4-wheel line to start . :thumme:
Sparrow
